Originally Posted by elow
Damm, your ride looks sick with that drop. Do you remember what size pads you have? The spacers really make a huge difference too. I may have to add some of those. How much did you pay for the spacers? The whole spring pad thing sux, i wish they would at least all come with the same size... because if you install springs just to find out that you need different pads you have to do the same amount of work all over again just to replace a pad.
i never checked the spacer part number when installing the springs... i guess i got lucky.
ps ~ i added another pic above.
spacer info:
h&r spacers and lug bolts (longer)...$190
front...10mm / rear...12mm
h&r trak+ spacers...part # 2455665 and #2055665. the bolts are 1/2" longer than stock and are supplied through h&r as well.
i ordered mine through: tc kline racing 614.771.7744 (ask for pete). they are located in ohio.
