andrew
~ head to the diy .25 carwash and select soap then rinse (hot water helps) ...no need for chemicals or degreasers. you do "not" need to cover a thing in the crossfire's engine compartment. i clean all my newer cars engines this way.
as for the pressure... i have used them for 20 years without any issue... ever. they do a great job with little effort and no product needed...
additionally, no issues with water and electronics... i do this at least once a month to my cars.
i use the same method to clean the underside of the hood insulator.
start at the bottom with the soap and work your way up (do not get too close to the material - 12" away of so)... then the opposite... rinse from the top downward and once you are home... open the hood to allow the water to drain to the bottom of the insulator (perhaps leaving the hood up overnight for through drying). pretty simple with great results!
and while your at it... don't forget the underside & well wheels... (and yes this car was a daily driver... rain & snow).
Thanks my boi I appreciate it
