Old Aug 4, 2013 | 03:51 PM
  #112 (permalink)
jmk41's Avatar
jmk41
Default Re: Best looking alloys on a Crossfire ever?
No not the exact off set I have a thread out there some where with a list of everything I had to buy but they will fit and run fine on the car with out a spacer I just didn't like the look with out them. The one picture in my gallery you can see the gap caused by the off set. These wheels added 10,000 miles or more of tire life. Our stock wheels are horrible on tires there is a thread about it also. Something that was not mentioned in this thread that is so important! ((Never ever just buy wheels and lug bolts put them on and drive the car! Even taking it to a shop could turn the same results)) Threading an over sized lug bolt into the rear hub will destroy your ebrake system when the bolts are even just torqued down but driving the car will surely destroy it. I order over sized lug bolts, did some math, and cut them to length. Then I ran the bolts in gently and gave the wheel a spin while jacked up to make sure nothing hit inside the hub. After finding the right length I cut the rest the same length and repeated the process. Using undersized lug bolts is a horrible situation as well do your home work or take it to a shop and explain this before assuming they know. Choosing a different wheel style over a half an inch is a bit meticulous you can easily make up the difference with a different tire size. Some one on here I believe was running a 285 I was running 265s those wore a lot better and hooked up way better.
