Old Aug 5, 2013 | 12:47 AM
  #113 (permalink)
JEFASOLD's Avatar
JEFASOLD
Default Re: Best looking alloys on a Crossfire ever?
Originally Posted by 2much2handle
*I am looking to keep the same size in the front but want a19x10.5 in the rear. Reason is I went with a wider tire in the rear 275/30/19 for more traction off the gate at the track but started experiencing what feels like some tire roll on the rim when taking curves at highway speeds. If I increase the width from 9" to 10.5" in the rear this should stretch the tire in a similar manner as the stock set-up. Does this sound right or will I run into other issues? Thanks in advanced.*
Not sure what tires you have but running Hankook EVOs 275-30-19s the recommended wheel width is 9.5. I am using .83 in spacers and they fill the space nicely and don't rub at all. I probably could have gone to 285s but the 275s are fine and the added track improves the cornering.
