Originally Posted by MI Roadster
Good info, Thanks for your posts.
I went out to see the trim of the window opening on the car and noticed that it has hard plastic molding on the outside that comes down farther than the rubber trim inside, and the window slides in between the 2 when the door is closed. I'm sure that helps with window leaks of water and wind. I don't think they could do that as well with the Crossfire Roadster because the edge has to be more flexible so it can fold down. That would help eliminate the water that drips inside the windows when I spray it with the hose water.
Thanks for the info MI Roadster, that clears it up for me.
