Old Aug 7, 2013 | 10:11 PM
onehundred80
Default Re: High low oil sensor on engine block
Originally Posted by David Woolrage
WNERE IS THE #$%^&*(OTHING????????????????????///
I called the Chrysler dealer and he said it was on the engine block, either left or right?
Anyone know for sure and have a picture you could send/fax to me??????????
Got the $200 + part and can't find out where to put it!
HELP PLEASE
David Woolrage 2005 Chrysler LTD convert slbyc07@verizon.net
Thank you _/)***
It is inside the engine oil pan, which has to be taken off to see the sensor. It is on the right hand side.
See the service manual.
OIL LEVEL/TEMPERATURE SENSOR
REMOVAL
1. Remove the lower oil pan. Refer to Page 9-663.
2. Disconnect the oil level/temperature sensor harness connector
(1).
3. Remove the two oil level/temperature sensor screws (1).
4. Remove the two harness retainer screws (2) and the oil
level/temperature sensor.
9 - 672 ENGINE - SERVICE INFORMATION
