Old Aug 8, 2013 | 06:28 AM
Filzring's Avatar
Filzring
Default US crossfire in Germany needs help by front suspension
A friendly good morning from Germany,
I am a 47 years old crossfire owner from cologne in Germany. I write here, because I have a US version of the crossfire that never was in the states.
Now I have a problem with my front springs. One spring was broken and I changed them.
As I checked the number, I read 1703210004 on the spring.
Normally the spring has the 193 321 0003 number.
The rubber in my car has 5 points and normally he must have 3 points.
The damper in front has the number V13, normally the number is V28 or V54.
The rear damper has the number H24, normally the number is H28 or H54.
So my idea is the suspension of the US version is maybe a little bit softer than the EU version.
Now my please is, have a look on your front damper. You can see a green number on down area of the damper and tell me this number.
Please excused my bad English, but I need the language not often enough.
Thank you very much for your help.
Stephan
