ibsorgn
cost of expensive maintenance the constant ping pong of bulbs going out, TPS warnings, and the other day a CPS going south.
Replace the bulbs with LEDs, never have to worry again. Solution = under $100.
Fill tires with nitrogen, never have TPMS warning again (unless a sensor dies). Solution = $40-$60
CPS, get bosch unit online at $45, buy necessary tools to replace at under $50.
I can see how these would be costly problems if taken to the stealership, but that is why this place is so valuable. Even if you can not wrench, you can buy the right parts, take it to an Indie mechanic, and know roughly how long it should take, all based on info easily found here.
No one here wants to see another owner having issues and not enjoying the car so most of us will do our best to help, hell there may even be a member close to you that will help with your maintenance, in many cases, for a few beers
Best of luck.
