Re: 1rst Gear Issue /High RPM's
I'm not sure that we're talking about the same thing, but the manual transmission is noted to feel "notchy" when shifting from first to second. Mine does, and I know that others have reported the same thing. Starting in 2nd does overcome this because of the close gear ratios, but it is a little harder on the clutch. You'll get used to it - I generally get rolling in first and then make an easy shift to second. Find what works best for you and go with it.
