Old Aug 11, 2013 | 06:35 PM
JEFASOLD's Avatar
JEFASOLD
Default Re: Oill filler extension
I want to take off the extension under the oil filler cap. I see it has an upside down spring catch which locks it in place. What is the best way to get it off without anything falling into the engine?
I do not want to destroy the extension, as I may want to put it back with the OEM air cleaner set up.
You need to remove the small secondary valve cover and just unscrew it from inside. It is a bit of a pain but I think that it's the only way to do it without destroying it.
