Old Aug 18, 2013 | 11:01 AM
SrWilliams's Avatar
SrWilliams
Default Re: Need Help Felllas
Pizza:
1. I am using the Kenwood Excellon KDC-X796.
2. I have the Kappa Infinities door speakers I do not know what what Kicker tweeters I am using.
3. Before the radio stops playing music I am getting sound from ALL of my speakers, to include the rear speakers. The sound suddennly stops playing even though the head unit continues to play (CD track keeps playing). then all of a sudden the sound in ALL of the speakers will kick back in. NEVER, does the sound cut out in one particular set of speakers.
4. The sequence of events is was as follows: I first purchased the Kappa Infinities. Hooked them up with the rear woofers, all to the amp. I was not using any tweeters at all. Everything played fine with no shutoffs. I then purchased the Kicker tweeters and hooked them up to the factory amp with everything else. That is when the shut off began. I then did everything in reverse. I unhooked the Kappas and only played the kicker tweeters with the rear woofers and no shut offs occurred. It is only when I hook the door woofers (Kappas), the Kicker tweeters) and the rear woofers that the amp cuts out. So, I am really of the believe that I am overloading the amp.
5. But this brings me back to my earlier question, if I am using the two speaker wires in the radio units wiring harness to connect the kappas to the amp then what wires in the harness do I use to connect the kicker tweeters to the head unit. The only other two remaining wires in the harness are used to connect the rear speakers to the amp (I believe).
