Old Aug 19, 2013 | 07:40 AM
Dennis B's Avatar
Dennis B
Default Re: New Owner of a 2004 Crossfire Coupe
Maelstrom's fix works, try this first. this is a common problem and an easy fix
replace your cabin filter. under the dash on the passenger side is a panel held in place with 2 Phillips screws. remove these and pull off the panel, you will see a black rectangular box
there are 2 clips that slide over allowing the cover to be removed
don't be surprised to find the filte rvery dirty
my radio ***** were the same as yours
I removed mine, (they just pull off)and cleaned them with brake clean
then I painted them with rustolium (sp) 'matt nickle' paint
let them dry in the sun for a few hours
they now look great and the color is a perfect match
hope this helps
we will be here when you need help with the cup holder and the headliner ;^)
Cheers
Dennis B
