05roadsterguy
I was noticing that You really never responded to Dinasrt's statement's.
You have an Issue a CAI will not fix. You should stop discussing CAI's and other mods and fix Your Car bro. I'm gong to jump in with Motormount. As I recall if the motor mount breaks She shimmies and shakes. There are some easy tests to do that will eliminate this very serious issue.
Look up broken motormounts.
Thanks a lot for the advice. you are right and that is what i was planning on doing first is fixing the problems before adding any modifications. ill look into the motomount and if you dont mind will let you know if that was the problem thanks.
