Need Help Tranny problems.
Aug 29, 2013 | 01:19 PM
26
permalink
rere985
Oct 2012
Re: Need Help Tranny problems.
2004 Chrysler crossfire base 141,xxx miles. on 8/12/13 the car went intolimp mode = (wont shift out 1st gear + check engine light) onthe drive home from work. I stopped at the local advance auto partsstore and got the code pulled. was (p0715) = speed sensor malfunction.
the speed sensors arelocated on a part call the conductor plate & the conductor plate is locatedinside the transmission pan on top of the valve body. you will have to order a newconductor plate the speed sensors are attached to it. on 8/13/13 I ordered anew oem Mercedes conductor plate from ebay $145 it came with part# 1402701161conductor plate + a new 13 pin connector, pan gasket & trans filter.the Mercedes part# 1402701161 conductor plate does fit all 04-08crossfires. avoid the dealership at all cost when it comes to replacingthis conductor plate. I found a independent local shop here in Louisiana whoreplaced the conductor plate and refilled the car with atf 4 trans fluid for$230 on 8/16/13. ok with the new conductor plate in the car will still be inlimp mode. Now its time to visit the dealership. you will HAVE TO take the carto the Chrysler dealership to have the (p0715) transmission code cleared $50.after that your good to go! happy smooth shifting again
http://www.ebay.com/itm/251203466574?ssPageName=STRK:MEWNX:IT&_trksid=p398 4.m1439.l2649
rere985
View Public Profile
Find all posts by rere985
