pizzaguy
If the battery is white, it's a Varta and PROBABLY original.
They are supposed to punch out the year and month of purchase, that's how you know when the warranty starts, so yes, there should be indication of install date.
The fuel pressure regulator and fuel filter are all in one unit. They sell in the aftermarket world for about $30. I've never tried changing one, I think it's four hoses and four clamps, not very involved, but there will probably be pressurein the lines when you loosen the clamps, keep that in mind!
If the fuel pump is bad, is the fuel filter part of the same thing.....as in if it the fuel pump which is covered under my vsc would the fuel filter fall under the fuel pump repair? Probably separate! Okay..I took two pics of the battery...definitely not original and I don't see any date unless it's somewhere other than the top.
