waldig
Its oil, nothing more. I run over full ( +1 QT OR SO ) all the time for the hard corners , so the pickup has a safety margin. High oil causes greater tendency of seal leaks, some small power loss, and possible foaming, though I have never seen that in any car.
My 73 challenger has 10 quarts in the pan and two get pumped into the oil accumulator for the next engine start up cycle, leaving 8 in the pan which has a big baffle tray. That motor always cranks with about 20 psi before the first revolution - thanks to stored oil pressure.
Its oil, less is worse. Your fine. W
dy Enjoy
pizzaguy
I doubt it. And for future reference, I only put in 8 quarts.
I had the "HI" indicator quite often in my Red Roadster, then someone on here suggested only putting in 8 quarts (it was Danimal). Since then, I never saw it come on again in the Red one. I continued this practice with my Graphite Roadster for the past 51,000 miles.
Thanks Folks! My mind can rest a little easier on this issue. That said, I will be changing my own oil from now on... Any recommendations on how-to resources for this?
