Thread: Oil Overfilled
Old Sep 3, 2013 | 03:52 PM
ala_xfire
Default Re: Oil Overfilled
Originally Posted by RoboJoe
Thanks Folks! My mind can rest a little easier on this issue. That said, I will be changing my own oil from now on... Any recommendations on how-to resources for this?
1. Use Mann fleece filter. ( HU718/5x )
2. buy Mobil1 0-40 from Walmart/Autozone/Advance/NAPA/CarQuest/O'Reillys in 5 qt jugs when on sale.
3. you can use either one of the vac pumps or do it manually. If you do it manually, replace the copper washer each time.
4. Jack the car up on the drivers side to promote better drainage at the right side drain hole. ( remove the bottom plastic belly pan if doing it manually )
5. when done draining, replace drain plug with new washer, then pour the new oil ( 8 - 8.5 qts ) in thru the oil filter housing, then replace the filter using the new O rings that have just a bit of fresh oil applied. ( HAND TIGHTEN THE PLASTIC FILTER CAP - THE O RINGS DO THE SEALING )
6. start 'er up and check for leaks at oil filter and drain plug.
7. replace belly pan ( after cleaning ).
( You can get the filters and copper washers from Rob at NeedsWings. )
