Old Sep 5, 2013 | 02:01 PM
boostmonkey's Avatar
boostmonkey
Default Re: Did it! Got my 11 tonight.
Originally Posted by velociabstract
Too much POWERRRR Jim. The tires start spinning if I pass 1800 rpm with the brakes mashed. The ABS/stability control system seems to penalize me if that happens. It's like when I'm giving it gas and left foot braking at the same time in Solo. A little is OK but too much and the computers can't decide what to do for a few moments and the lap is ruined. However your on the money. I'm loosing lots of time off the line. 1.848 is pitiful with drag radials. When I learn, I'll be hunting Anthony's non nitrous times. (A guy can dream) Thanks again everyone!
Les
Same here. The torque converter won't stall above 1800 or so. I get my best launches with a 1400 rpm stall. I also run 16 psi in the MT ET Street radials and they hook GREAT. On a good track I go straight to WOT with zero wheel spin. I will cut 1.85-1.89 60' times, but that is torque limited, not traction limited.
If you are at WOT and not spinning your tires, you can't launch any faster without more power, lower gearing, or higher stall converter.
CONGRATS ON MAKING IT INTO THE 11 SECOND CLUB!!
