Old Sep 5, 2013 | 06:33 PM
onehundred80
Default Re: Alarm keeps going off
Originally Posted by Muskoka
So, the latest is they say the power control module, is gone. When the horn was un hooked, the PCM shut down, they can't re program it (basically in shut down mode due to the alarm). Since they can't re program it, I need a new one. This is a $2500 part. Does anyone know anything about this or if it makes sense. Can't use a used PCM, because cross fires can only use new ones that have never been programmed before, so have to go new. The part number is 68027422ab.
Does anyone know where to get a cheaper PCM or crossfire parts?
With the PCM gone, is their fault because it was fine when I brought it into the dealership? Or was it done anyway because it was setting off the alarm haphazardly? Should I be paying for this since they un hooked the alarm and thus screwed up the PCM?
They screwed it up and should fix it. Complain to Chrysler at least, but these people are crafty sods, They'll say it costs $2,500 and then say that as a good will gesture they will let you have it for $1,750.
I am sure it can be re-programed, but maybe not by those idiots.
Let's face it if all the data on it was written in stone we would be replacing the mother boards in our computers all the time.
