Old Sep 6, 2013 | 05:44 PM
bri3d's Avatar
bri3d
Default Re: Project 69 ... XF 370
Originally Posted by bigblock427
It's the same engine block. If the accessories will bolt up depend on what car the engine was used in. Engines accessories which were used im ML, or G class cars, or Sprinters often differ from normal passenger cars. For example oil pans and so on. So it's best to research that in MB EPC before you buy an engine. I also would recommend to use to use the original Crossfire ECU with a 3.7 tune, because that's easier than to setuo a 3.7 ECU to a Crossfire SKREEM and BCU.
Regards
Markus
Great info Markus, thanks!
This swap is only really interesting to me because it can mate to a 6-speed and avoids the ECU issues and just needs a tune. Otherwise I would be hunting for a V8.
