Re: How to Repair Relay Control Module (RCM) - (Mystery no Start)
Had the no crank issue while shopping - figured it was an interlock. Walked home 6 miles and started reading the forums and found this issue. I went back to work on it after 3 hours and it started right up. Took it apart and the center solder posts were cracked. Repaired and restarted. Then the BAS/ESP light stayed on...rechecked cabling and back to the forum again. Found the suggestion of turning the steering wheel lock to lock and it worked. THIS IS A GREAT FORUM!!!!
