Old Mar 29, 2006 | 07:42 PM
HDDP's Avatar
HDDP
Default Re: Alignment and Camber Kit
Originally Posted by akilgore
The dealership doesn't have the camber kits in stock and it sounds like they've got the car torn apart in the meantime. It'll be Friday afternoon at the earliest before I get my XF back and they've had it since yesterday morning. I'm self-employed and unless my husband wants to ride his motorcycle in the rain so I can drive his truck, I need wheels.
To me, the drives like a dream. It doesn't pull or bump or anything. I just wanted an oil change.
Please excuse the following statement. You just got bent over the bench !
There is no reason for an alignment on the car unless the alignment is off. I would call them ASAP and ask for a print-out of the alignment specs. on your car before they attempt to do anything. Ask for the print out of the #'s they are showing on the machine. When you take a car in for alignment, the computer reads the camber and caster of the wheels before they do any changes. They compare those #'s with the factory specs. then adjust from there. Then they do another print-out after the alignment is adjusted.
Camber adjustment bolts are usually only necessary on cars that have been damaged in a collision or have had suspension modifications. There are 4 principal measurements that they need to do on their alignment machine / Camber - Caster - Toe - Turning angle Diff.
The specified range for the car is FRONT / Camber -1.5 to -0.9 / Caster 4.7 to 5.7 / Toe 0.08 to 0.25 / Turning angle Diff. -1.92 to -0.92 FRONT / Cross Camber -0.3 to 0.3 / Total Toe 0.17 to 0.50 / REAR / Camber -1.6 to -0.6 / Toe 0.22 to 0.33 / Total Toe 0.43 to 0.67
I'm almost tempted to have you give me their phone # and contact them directly. This kind of stuff pisses me off.
