James1549
Not sure how to do that while it is in the car. That entire assy will come out with a little work. Remove the interior trim piece on the trunk lid. Then you will see 10 -12 bolts/nuts. Remove the nuts, disconnect the wire plugs and it will come out from the top.
James
James:
Thans for the quick reply. I figured it came off from the top after removing the entire assembly from the top. I located the ten screws and bolts and after unfastening them the plastic cover is still affixed to the body. Unloosening the ten bolts did not dissengage the cover and I thought it would like you suggested
