Old Sep 12, 2013 | 09:46 PM
pmg12345's Avatar
pmg12345
Default
Originally Posted by Adrian_X
All I can say is that if you get lucky enough to find marker lights with CANBUS built in that actually work and last longer than a couple months, you sir will be awesome. Me and Mr.Miata there have spent money and time going through multiple LED options a little while back trying to find said parts. So far, there's little to no luck in that department.
Good luck to you, friend.
I've installed canbus bulbs for all 4 turnsignal lights and get no error on the dash. Thats the good news. but now i have the dreaded hyper flashing syndrome when i turn on either turn signal or the hazard switch.
i have searched thru lots of posts from the search engine that discuss hyper flashing but most are old and claim no solution. Anyone know the answer or the thread that i should be looking at to deal with this? my understanding is that there is no flasher module to modify as its electronic and built into the turn signal switch/cluster if i screwed something up along the way.
This newbie could use a hint, please.
