Old Sep 13, 2013 | 06:02 PM
ericfragola's Avatar
ericfragola
Default Re: Trans fluid type revisited
Hi all,
I called dodge today about atf fluid. They have Mopar fluid part #5127382ab
It says on the bottle that it meets MB specs of 236.10 and 236.12 at $24 a quart there
Then I called Mercedes and they have atf fluid part #001-989-68-03-13 and that meets approval 236.14 at $20 quart
I also see some people recommend fuchs titan atf 134 over the MB fluid.
From what I understand, the nag1 transmission uses 236.14. is this correct?
Im seriously having the hardest time finding a straight answer on what I need to use. I understand the specificness of the AT's and how specific the ATF needs to be which is why I'm making sure before hand.
bottom line question - which spec does my 04 crossfire ATF fluid need to meet? .10, .12, or .14?
Which would I need?
Any input is greatly appreciated. Thanks
Eric
