Old Sep 13, 2013 | 07:17 PM
onehundred80
Default Re: Trans fluid type revisited
Originally Posted by ericfragola
Hi all,
I called dodge today about atf fluid. They have Mopar fluid part #5127382ab
It says on the bottle that it meets MB specs of 236.10 and 236.12 at $24 a quart there
Then I called Mercedes and they have atf fluid part #001-989-68-03-13 and that meets approval 236.14 at $20 quart
I also see some people recommend fuchs titan atf 134 over the MB fluid.
From what I understand, the nag1 transmission uses 236.14. is this correct?
Im seriously having the hardest time finding a straight answer on what I need to use. I understand the specificness of the AT's and how specific the ATF needs to be which is why I'm making sure before hand.
bottom line question - which spec does my 04 crossfire ATF fluid need to meet? .10, .12, or .14?
Which would I need?
Any input is greatly appreciated. Thanks
Eric
This is the definitive answer;
Originally Posted by rcompart
Mercedes ATF Transmission Fluid MBZ Approval:236.10 001989210310 - RM European Auto Parts
This is the exact same 236.10 fluid Mercedes used to sell without the MB label on it and is the correct spec for the 722.6 transmissions.
You can use coupon code SUMMER2011 for 3% off your order up to $150.
Remember----- 236.10
The Owners manual says to use Shell 3403 ATF.
