Thread: battery drain
Old Sep 16, 2013 | 04:23 PM
onehundred80
Default Re: battery drain
Originally Posted by chris1_uk
hi guys i did try looking for an old post on subject but couldnt see one
on my 2004 crossfire the battery keeps draining, ive tried putting a brand new battery but after a short while again the battery drains
would be very greatfull if someone might have a few ideas for me to see what is causing the drain
cheers chris
What time frame are we talking hours, days or weeks?
You should check all the other fuses after checking the fuse #9, put a digital voltmeter set to Ma across the two terminals that the fuse connects. There are posts on this.
Add up all the readings, there is a number (35 Ma) that this should not exceed, I think that is the number mentioned in the link. Some fuses will have no reading and others a small amount which keeps the memory alive etc in some accessories or parts.
