Ultimate Performance Alignment **specs inside**
Sep 16, 2013 | 04:48 PM
permalink
boostmonkey
Jan 2011
528
Re: Ultimate Performance Alignment **specs inside**
The adjustments are only so precise. The readings on the screen would vary 0.1 degrees without touching it. Furthermore, adjusting one item, affects the others.
My car is not lowered. Stock springs and shocks.
The autocross yesterday was a blast!
I learned several things. One: The outdated 280
treadwear Continental Contisportcontact 2 front tires I have could not compete with the 140 treadwear tires the rest of the STR class was running, and were ultimately, I think, a limiting factor. What I would do is fly into a corner, push the front tires past their limit and they would push wide, at the apex I would use the throttle to rotate the rear of the car around and get lined up exiting the corner. I drifted out of more corners than not, which was QUITE fun, but probably not the fastest way around the course. By the way: you CAN steer the car with the throttle, and it is awesome. I have
200 treadwear Dunlop
Sta
r
Specs on the rear and they felt
better suited for the task.
I was very pleased wit
h the driveabil
lit
y of the car. I could push it around between understeer, slight oversteer, and wild
oversteer without it doing anything unexpected.
I could power ou
t of a corner holding just a few degrees of overst
ee
r without it acting like it wanted to
swap ends, which was
great. I never hit a single co
ne, at least not hard enoug
h to knock it over. I may have kissed a few.
I never sp
un either. I came close once - I went
into a downhill 90
* corner way too fast, a
nd was pushing through it
and
headed to hit the outside cones on the exit
. I
punche
d
the gas to rotate the car - which did the trick - and just missed the cones, with the back bumper, instead of the front fender.
I got all kinds of sideways, but didn't want to bail
so I kept
working the
gas and see
sawed left-right-left. Amazin
gl
y I got around the next corner
(a gentle left kink
sideways, and got it under control
just in time for corner
3 in this sequence (another tight right
-hander)
, wi
thout hitting any cones anywhere!
The
only place the car was loose was on the slalom. They had a long sl
alom that you entered slowly and had to bu
ild your speed in the sl
alom. If I got going to fast by the end I would be pitching the car back and for
th and the rear would get loose. It felt like I would throw it to one si
de, counter-steer
to ca
tch it, and throw it t
o the
other side. If I kept the speed lower, the sla
lom was
perfect.
I talked alignments with the Honda S2
000 guys
which comprised the majority of my class. I could not compete with their times. But they
were all seasoned regulars and their cars
were prepped specifically
for the c
lass. The
y run crazy alignment specs: -3 degrees of cam
ber all around
, and a good bit o
f front
toe
OUT.
That would shre
d the inside edge of your tires going
down the highway
Those
S2000 engines are so weak thoug
h. The
y were dropping the cl
utch at 6000 RPMs to get
a good launch
and not bog.
I told them tha
t I was spinning the launch no matter how lightly I touched the throttle
(horrible surface)
One
of them said to me
Y
ou proba
bly need to lower your RPMs. What RPM are you launching at?" I
said "1200"
and he looked at m
e
like I had three eyes.
Overall I had a great time and
was happy with the ali
gnmen
t
. For my mi
xed use, I am going to leave it right where it is at.
boostmonkey
View Public Profile
Send a private message to boostmonkey
Find all posts by boostmonkey
