Old Sep 17, 2013 | 10:12 PM
JHM2K's Avatar
JHM2K
Default Re: Issues keeping Magnecor Wires plugged in?
That's a damn good find!!
I guess that answers the question about platform compatibility... LOL:
  • SET contains 6 coils. Enough for one 6 cylinder engine
  • New not remanufactured
  • Replaces dealer part numbers: A0001587303, 000 158 78 03, 0001587303, 5098138AA, 00107, 0221503035
  • Built to strict quality control standards
  • Direct replacement
  • 100% factory tested
  • Has a 3 pin electrical connector
  • Fits the following Chrysler & Mercedes 6 cylinder engines as listed:
    • V6 2.6L, 2.8L, 3.2L, 3.7L,
    • L6 3.2L
Brand NEW fitting for the following years and models:
  • 2005-06 Chrysler Crossfire Ignition Coil (Set of 6) for Models with V6 3.2L Supercharged (8th Vin Digit N)
  • 2004-07 Chrysler Crossfire Ignition Coil (Set of 6) for Models with V6 3.2L (8th Vin Digit L)
  • 2001 Mercedes Benz C240 Ignition Coil (Set of 6) for Models with V6 2.6L
  • 2002-05 Mercedes Benz C240 Ignition Coil (Set of 6) for Models with V6 2.6L (engine ID 112.912)
  • 1998 Mercedes Benz C280 Ignition Coil (Set of 6) for Models with V6 2.8L
  • 1999-00 Mercedes Benz C280 Ignition Coil (Set of 6) for Models with V6 2.8L (engine ID 112.920)
  • 2002-04 Mercedes Benz C32 AMG Ignition Coil (Set of 6) for Models with V6 3.2L Supercharged
  • 2001 Mercedes Benz C320 Ignition Coil (Set of 6) for Models with V6 3.2L
  • 2002-05 Mercedes Benz C320 Ignition Coil (Set of 6) for Models with V6 3.2L (engine ID 112.946)
  • 2003-05 Mercedes Benz CLK320 Ignition Coil (Set of 6) for Models with V6 3.2L
  • 1998-02 Mercedes Benz CLK320 Ignition Coil (Set of 6) for Models with V6 3.2L (engine ID 112.940)
  • 2004-05 Mercedes Benz E320 Ignition Coil (Set of 6) for Models with V6 3.2L (engine ID 112.954)
  • 2005 Mercedes Benz E320 Ignition Coil (Set of 6) for Models with V6 3.2L Diesel (engine ID 112.949)
  • 2003-04 Mercedes Benz E320 Ignition Coil (Set of 6) for Models with V6 3.2L (engine ID 112.949)
  • 1999-03 Mercedes Benz E320 Ignition Coil (Set of 6) for Models with V6 3.2L (engine ID 112.941)
  • 1998 Mercedes Benz E320 Ignition Coil (Set of 6) for Models with V6 3.2L
  • 1999-03 Mercedes Benz ML320 Ignition Coil (Set of 6) for Models with V6 3.2L (engine ID 112.942)
  • 1998 Mercedes Benz ML320 Ignition Coil (Set of 6) for Models with V6 3.2L
  • 2003-05 Mercedes Benz ML350 Ignition Coil (Set of 6) for Models with V6 3.7L
  • 1999 Mercedes Benz S320 Ignition Coil (Set of 6) for Models with L6 3.2L (engine ID 104.994)
  • 2006 Mercedes Benz S350 Ignition Coil (Set of 6) for Models with V6 3.7L
  • 2001-04 Mercedes Benz SLK230 Ignition Coil (Set of 6) for Models with V6 3.2L
  • 2002-04 Mercedes Benz SLK32 AMG Ignition Coil (Set of 6) for Models with V6 3.2L Supercharged
