Old Sep 18, 2013 | 05:20 PM
JesseJamessrt6's Avatar
JesseJamessrt6
Default Re: datalogs LEAN AFR
[QUOTE=JHM2K;758826]You guys do realize that
<11 = rich
>12 = lean... right?
Jesse -- 9.6 AFR is a bit fat, you can lean that out and recoup some horsepower. If you're at ~10.9 under WOT at max boost, that's about where you want to be based on my memory from Anthony's best tunes.QUOTE]
Wow, I really messed this one up. You're right. So I am not lean according to the graphs, it is rich. Not a dangerous problem, just not ideal, right? Sooooo, I have room for more boost!
Tunaglove, thanks for pointing out that I need a baseline and to see if things are calibrated. I opend all the files back up and am consistently showing 14.7 AFR for normal crusing, ie. 15-20% TPS and around 2,000- 2,500 RPM.
I would like to get a reading on the IAT's, what is the best way to tie this into the wideband?
