[QUOTE=JesseJamessrt6;758930]
JHM2K
You guys do realize that
<11 = rich
>12 = lean... right?
Jesse -- 9.6 AFR is a bit fat, you can lean that out and recoup some horsepower. If you're at ~10.9 under WOT at max boost, that's about where you want to be based on my memory from Anthony's best tunes.QUOTE]
Wow, I really messed this one up. You're right. So I am not lean according to the graphs, it is rich. Not a dangerous problem, just not ideal, right? Sooooo, I have room for more boost!
running fat can be just as dangerous as running lean. you can wash down the cylinders causing a burn on the cylinder wall. 11.8 to 12.2 is were you want to be
Tunaglove, thanks for pointing out that I need a baseline and to see if things are calibrated. I opend all the files back up and am consistently showing 14.7 AFR for normal crusing, ie. 15-20% TPS and around 2,000- 2,500 RPM.
I would like to get a reading on the IAT's, what is the best way to tie this into the wideband?
using the dashdaq you can log iat thru it.
austinbarrylee
I was told by previous owner inmotion
crap tune
Buggin
Reading this, I seriously need to put my stock injectors back in and sort out the other problems...
no need to replace the inj. just need a decent tune. i ran 550 cc inj. stacked pulleys, sl55 fuel pump and 11.9 afr at wot. it was all in the tune running 5% lt/ft
austinbarrylee
Once a car has been tuned does it need to be tuned again. How can tell if a car is out of tune. The mechanic hooked the car to computer turned the key and said the sensor was good. I live in Louisville Ky no one knows anything about these cars.
cars dont fall out of tune unless you change your mods. tunes are updated due to weather conditions or power adders. if you tune for conditions and dont change anything the tune lasts forever
austinbarrylee
Yes totally understand. Typo. I have been told that. Super dangerous. The engine is running super strong. I'm thinking its the sensor. The gauge is old. I have not seen it in the green. Its stays at 14.8. All the time even in WOT. I took the car to dealership they hooked it up to the computer and told me my o2 sensor were good. I totally confused about it. If you have experienced an AEM gauge I would appreciate the help.
14.7 to 15 afr during a cruise is normal for closed loop driving. open loop ie: wot needs to be 11.8 to 12.2 . if the gauge is bad why trust it?
