Re: datalogs LEAN AFR
Gotcha. I worked with Jerry on multiple tunes to get where I am at. I will run it again next week and see if the ECU has adjusted any. I think Rob sells a fuel gauge that I may buy.
I am with you on the injectors. I was going to go to the fuel filter, regulator, and then injectors if necessary.
