oil leak
I have a 2007 limited with an oil leak on the drivers side. It is leaking from where you put oil in it on top of the valve cover, I can see 2 torx screws and have verified that the cap is on it correctly. Has anyone had this problem and is that part on the valve cover removable to replace the gasket, and how do you get the cover off the top of the engine to access it?
