Old Sep 23, 2013 | 02:05 AM
blueeyes147's Avatar
blueeyes147
Default Re: lowering battery voltage, engine startup problem
What is the age of the battery? These cars are very fussy about old batteries.
Also, check the condition of the battery cables, check battery ground cable at both ends - clean and tight?
the battery has been replaced recently because of this problem, install a more powerful and were also cleaned and replaced the cables with thicker cables after you have cleaned everything, for some times went well, but then the problem came back, I think because the car has very little
