MoparFreak69
In my opinion the harmonic balancer looks like it is fine. Typically when balancers start to have problems the outer ring will walk off the inner ring, which is bolted solid to the crankshaft. Yours appears to be running true and isn't wobbly like some can get with partial separation. The rubber looks slightly dry, but isn't cracking horribly like a tire that has sat out in the sun for decades. I would run it, but I would give it a good inspection after every oil change.
Just my $.02
Can I lightly tap that ring back in where it's coming out? It was hard to get a video of what looks like wobble. In person it looked a lot rougher. I could just be seeing things.
Also, if it's "not that bad but check on it" could I just replace it with the V6's? They are the same size from what I gather.
