Old Sep 23, 2013 | 05:55 PM
sk8erjosh09's Avatar
sk8erjosh09
Default Re: Opinions on Crank Pulley Please!
Originally Posted by MoparFreak69
Duh, I forgot, you are 2 cylinders longer than normal!
Do you have access to a lift or some wheel ramps to get the front of the car high enough to use a long breaker bar? There should be enough compression to allow you to yank the breaker bar sharply and quickly to break the bolt free. Might take a couple attempts, but should be feasible. Tightening will be a bit more difficult, but should not be impossible.
If I take out the fan and shroud I could try that. With the breaker on through the top I only had ~4in of play. I didn't bother trying to yank in any direction. But I can give it a shot with everything out of the way. Thanks again for all the help!
