Old Sep 24, 2013 | 09:40 AM
sk8erjosh09's Avatar
sk8erjosh09
Default Re: Opinions on Crank Pulley Please!
Originally Posted by JEFASOLD
The fan and fan shroud come out without tools, just unplug electrics, pull 2 clips at the top and gently lift it out. A short impact wrench should then fit in there and should do the job. And yes, you need a new bolt every time. It is a special stretch type when torqued, good for one use only.
You are forgetting I have the V8 and a mechanical fan . The added length is way too long to fit any impact gun I have seen.
If I replace it I will buy a new bolt though.
Last night I pulled the fan and belt, I thought I fixed the leaks from the gasket on the water pump so I put the belt back on and I couldn't see any wobble at all from anything. Can't really explain why, because I would have thought the belt would pull itself into alignment but I guess not?
Anyway, one thing down now on to the water pump!
