Old Sep 24, 2013 | 11:53 AM
onehundred80
Default Re: SRT-6.com exclusive New Grille through Karl E.
Originally Posted by JEFASOLD
I think the problem with these grills isn't the quality of the work, it is the fact that they don't follow the design of the car. The car has shallow angles on each side, meeting at a central point, the original grill follows that design. The aftermarket grills need a crease in the center or something to indicate the center of the grill. As is it looks as if they were designed for another car and transplanted.
I agree, there is more to making these things than meets the eye. Fitting something with a small gap which is even all around is precision work. Any error is easily spotted and makes it all look cheesy. Just making something and saying that's good enough is not going to pass the requirements of those on the forum with high standards. If the bottom grilles are attached using plastic ties then that will fail also. The top grille should attach with the screws at the top and not have a flaky attachment at the bottom or this grille will end up as road kill.
This is not to my taste either for what that's worth, which is probably not even a pinch of you know what. The wire mesh grille has already reached over kill status.
