Old Sep 24, 2013 | 05:29 PM
onehundred80
Default Re: Central Locking (potential problem)
Originally Posted by FAB Cruiser
Hi guys,
I've found a lot of posts on this subject but wonder if anyone has had this specific problem?
I've had the Crossfire for a few weeks. The central locking works fine but here's what's happening:
When I unlock with the remote, everything opens fine (drivers door first press, other locks second press). However, the Central Locking pump continues to whir for a further 20 seconds or so.
When I lock the door, everything locks except for the fuel filler flap. The pump continues to whir for about 20 seconds then just before it stop, the lock snaps shut on the fuel door.
The dealer I purchased the car from has arranged for a diagnostics specialist to look at it but I wonder if there are any specific pointers I should give them? e.g. I was wondering it the delay with locking the filler door is a sign of a leak from that particular hose?
Cheers
David (UK)
I would suspect a leak somewhere in the filler cap system.
A positive pressure or vacuum has to be achieved which will then shut the pump off automatically.
From the manual;
The door lock actuators are pressurized. When a pressure threshold is reached in the system, the pump is switched off by an internal pressure switch.
It goes on to say the same principal is applied when unlocking.
