Old Sep 24, 2013 | 05:56 PM
  #66 (permalink)
Billy22Bob's Avatar
Billy22Bob
Default Re: datalogs LEAN AFR
In my signature there are two links regarding solutions for running lean. The first (181) was solved by adding the Pierburg pump. When I added a smaller SC pulley with the 181 (stacked) the Pierburg was no longer enough. At that point I added the 550CC injectors and was seeing plenty of fuel even at 23psi. Keep in mind, that's with stock fuel filter and fuel pressure.
- 181 Lean solution
- 185 or Stacked Equivalent Lean solution
Great stuff.....lends cred to a "simple easily reversible upgrade setup...
65mm - 17psi - stock just makes it on AFR no retune necessary - within the capability of ECU
61.9/155 or 74/181 - ~18psi - upgrade to the 7.00228.51.0 and get a tune - ie: no need to change filter/reg.
65/181 or >19psi and you need to go with some 550cc injectors + fuel pump + tune but still keep your filter/reg. but your hitting 400-450 bhp and 300-350rwhp
HANG ON!!!!!
Apologies, if I have put any Walbro users off side.
good prices for a 7.00228.51.0 appreciated.
I found one in Aussie for AUD$375 here a little exxie for my taste tho.
