Beaner
It did solve that weakness (pin through spider gears issue). It made the next weakest part fail. Once the ring and pinion gear issue is solved then my guess will be the rubber ring in line of the driveshaft to the rear end... after that maybe the rubber mounts for the whole rear suspension. it is a vicious cycle when more and more power is added.
Ahhh thanks for the clarification and yes, that's all part of modding for greater power.
