Old Oct 1, 2013 | 01:29 AM
victorinoxs's Avatar
victorinoxs
Default Re: 1rst Gear Issue /High RPM's
Are you saying you have to rev it to 3,000 just to get ROLLING? That would be, to me, an indication of the engine developing too little power.
I'd look at fuel pressure, MAF sensor, vacuum lines, etc.
Somethin' not right here!
Hi Pizza guy, after doing a little more research i have found another guy had the same issue on a BMW M3, when the car is completely stopped and only to get it rolling on 1rst gear it would take him above 2k RPM's before the car would start to "stutter".
it was indeed some sort of loss of power. it ended up being the "motor mounts", after replacing them the problem was gone.
i might have them check as well.
