Thread: Door Lock Help
Old Oct 2, 2013 | 12:25 AM
onehundred80
Default Re: Door Lock Help
Originally Posted by Arkiduca
They still lock, but the problem is when I open my door, all the locks unlock.
This can be changed by reprogramming.
And when the doors are open, I can't lock it.
The driver side door will not lock if it is open, I believe the passenger side will.
And when I insert the key on the outside, it will turn easily enough, but nothing happens. It's still unlocked.
Do you mean when the door open?
And the FOB for whatever reason doesn't work. I've replaced the batteries and still nothing.
The fob may need to be reprogrammed after the batteries have been changed and the fob was without power for some time. The instructions for this are on this forum.
So I'm wondering if there's something disconnected between the keyhole and the locking mechanism? And if that's the case, how do I get to it? I've taken the driver's side door panel off before, but I didn't try to remove the lock due to time constraints.
There is a switch in the lock or close to the mechanism that is activated when the key is turned, but the door must be closed of course.
