Re: Door Lock Help
Arkiduca
When the door is closed, I try to lock it with the key and it won't lock.
I'm going to look into that this weekend. Is there any guides or pictures avaiable to see where the switch is or what it looks like?
On 8Q - 45 of the Service manual for the 2004 you can see the circuit that the key operates when it is turned in the drivers side door lock. So there is an electrically operated switch in the door lock mechanism somewhere, this starts the pump in the trunk area.
Here is a PDF that has a picture of the inside of the door with the inner panel off and the sound deadening material removed.
CLICK
