Hi Josh,
i think we talk past each other. Camshaft and Crankshaft Position Sensor work together. You can't generate the position of the 1 cylinder from the Crankshaft Position Sensor, because you have 4 strokes and 8 cylinders.
I'm not talking about the signal that is sent by the ECU to the Camshaft Position Sensor. I talk about the signal that the ECU gets back from the Camshaft Position Sensor. This has to be a clean square wave signal on the oscilloscope.
Regards
Markus
