Re: I want 18" Tires w/identical tires on all Four wheels
I just assumed you'd want to go wide. If you want to be able to rotate 4 ways and are a hyper miler it can be figured out. You can put 18x8 on all four corners with a 32 offset and it should work. I doubt the cost of the rims will equal any savings from being able to rotate the tires.
Les
