Old Oct 7, 2013 | 12:15 PM
onehundred80
Default Re: Crank pulley seperated. Checked after low oil light.
Originally Posted by Benflitv
Yes. It is the SRT. I heard with the 68mm pulley I have can be coupled with the 178 crank pulley with great results. I'll have to do some more searching on that one.
Thank you for the link for the OEM pulley.
I am really concerned with the oil light though. I smelled the exhaust, also when revving, and don't see or smell oil. There are also no oil leaks. Oil problems can be catastrophic. I hope there isn't something major wrong.
The sensor can go wrong and give you a red light. That is the common problem. Replacing the sensor is a pain in the rs but it is a cheaper repair than any other cause. I cannot find where the instructions are to check it with a multimeter though.
