onehundred80
Can you change the speed of the fan as normal? If so it is not the resistor.
The resistor is what varies the speed of the fan. What are the symptoms?
Hi
Thanks for replying so quickly, the fan operates as it should, it speeds up and slows down when I alter the fan speed but it doesn't blow hot air when I change the dials showing the blue dots to the red dots, cheers
Elena
Than
