Re: Heater blower resistor
ElenaB
Hi
Thanks for replying so quickly, the fan operates as it should, it speeds up and slows down when I alter the fan speed but it doesn't blow hot air when I change the dials showing the blue dots to the red dots, cheers
Elena
Than
Then I would say that it is the heater control the unit with the red and blue dotted dials or the heater valves under the hood near the battery. These are the two silver cylinders about 2" high side by side. Maybe Graphite Ghost will add his ideas as he has worked on this problem.
