Old Oct 10, 2013 | 09:05 AM
onehundred80
Default Re: Crankshaft Position Sensor strikes again!
Originally Posted by gguillot
The CPS in my '04 decided to go TU with absolutely no warning. At only 53k miles, I didn't really think it would go anytime soon, despite what I have read here on the forum.
Five minutes after leaving work, in rush hour traffic, the XF just quit as if the key had been shut off. It started again after 15 minutes, but I only got another 2 miles before it went out for good. Had to call the tow truck.
Anyway, the CPS is readily available - I found it on Amazon for $40 (Bosch OEM), so I ordered TWO - will keep one in the car as a spare. Followed the great replacement instructions in the Sticky. Easy 15 minute job.
One word of advice - you must get the 7/16 drive bit for the bolt on the CPS - there is not enough clearance to fit a 3/8 drive socket (at least not on my engine.) Also, I had to lightly sand the shaft of the CPS to get it to fit into the very tight hole in the engine.
Keeping a space CPS and socket wrench in the car from now on....
You have been forewarned.....again.....
Re reading your post I think you may be referring to the size of the square drive. In that case I think you mean the 1/4" square socket and not 7/16".
Correct me if I'm wrong, I am wrong quite often and I will not get upset.
Last edited by onehundred80; Oct 10, 2013 at 09:15 AM. Reason: Re read post meaning
